conversion famines
  • Thread starter Thread starter zippovito
zippovito
Hello everyone
I have files made with 3d max study of a famine of the duchies, would serve me in any file with surfaces (step, iges.)
as well as quality. . .
Could someone give me a tip? ? ?
good work at all
I do not know if the files of 3d studio max are usable to export in automotive quality (hardly).
It is likely to be used as a basis for a reverse operation (always having an acceptable level of detail).
If you have confidentiality issues you can contact me in private so you send them to me and after seeing them I can tell you the best way.
at salut.
Hello everyone
good work at all
you can post the file in stl would like to try it too
Hello everyone
good work at all
hi post a cloud of stl format points we see to give you a hand all the present of the forum :biggrin: either here or in private as you want
maximum availability
Hello everyone
spend two poaroles to introduce me
are mechanical engineer use solidworks since 2001
automatic plant design, machines, structures.
I am creating a special based ducats 916.
I bought the frame, engine, fork, fork. . .
before switching to the installation I would like to check the aesthetics and functionality of the changes - details.
I bought famine files online, but they were made in 3ds.
now I attach the cupolino, small file and perhaps easier management, we will pass (spero) to the more complex ones, side fair and cupolino! ! !
waiting for good work to all.
Hello everyone
hi zipp..
you should post a .stl file format so you can read it all:rolleyes:
I imported the file into solidworks at the opening gives me the warning: "coordinate missing plots" consequently fails to save the file directly in stl, so I saved it as part.
if there are other suggestions, perhaps opening the .3ds file in another program and saving it as stl..
in iges can you save him?? I do not have solidw but use catia, or wait for someone who saves us the.sldprt in stl
boys, as I suspected the 3ds file is a triangular file and not of surfaces.
for which it is necessary to proceed with a reverse operation to obtain surfaces and solids, provided that the model is correct from the geometric point of view.
Here I am. .
converted file to stl
I hope it's okay. .
Good evening to all
I've already converted two posts before.
as I told you the files of this type are not convertible into surfaces or solids, you have to go through reverse.
the file you posted has several quality issues, many details are approximated and is not symmetrical compared to the lungitudinal plane.
so you will never get the real hull as it should be.
I too a few days ago from 3d studio max I imported on catia a model, unfortunately I no longer had occasion to work on it, but if I don't remember badly I started to go to put on all connections of the triangles a curve, then you should go to close the surface. at a qualitative level is certainly not a class a but the results in a cam can be interesting
Staff online
