constraints
  • Thread starter Thread starter cocos84
cocos84
Hello.
I am building a simple hydraulic cylinder and I am working in the assembly designers environment.
I would like to insert the bonds together between the various components, I go to fix one of the components in space through the icon in the shape of yet but when I move the manipulator on the component I still can move it in every direction, even if it presents the bond in the shape of again. the same applies to other constraints between the various parts.
how do I move the components according to the constraints I have established.
Thank you. .
you must use the "manipulation" command and set the "respect of constraints" box.
You can then move the stem axially if properly bound.
Hello.
Thank you. .
positions the compass icon on your object and drags holding the ctrl
Thank you guys very much, trying and retrying I managed to get what I wanted.
After entering the constraints to move the components with manipulator I have to after having attached it to the holding shift component to respect the winches and shift+crl to respect both constraints and interference.
I tried to use ctrl+shift keys simultaneously to respect constraints and interference.
for the constraints everything ok
for ko interference:
the yellow component penetrates the blue component....
What's wrong?
you have to activate the option of internetration control.
if you use the manipulation window just activate the option retains constraints, if you use the compass just hold the control button.
But be careful if the two bodies penetrate the system at least, I don't signal the interconnection.
How come this behavior?
Catia should also report the small interference, right?
In my opinion, it has led to think that the workbanch product, is an environment that simulates cinematisms, but this is not true, it simulates the assembly and the different configurations, not the transitions from one state to another.
in the wb product you have the command of analysis of compnetration, but if you want to analyze the clash between the parts in motion you have to avail of the form of cinematics, that I signal the areas while the bodies are in motion, to consivderali the same thing you have to wait for the v6, where instead of the alleys of together you will find the mechanisms of cinematisno.
to share the same thing you have to wait for v6, where instead of the lanes together you will find the mechanisms of cinema.
This is a nice news:eek:
So, in the assembly environment, will I no longer have the constraints bar (the one with the anchoretta)?
In efetti it has been hidden more than made disappear, however you will immediately find that of the mechanisms of the form of cinematisms, so for example, you will find the swivel joint, which guides you to create a coaxiality and a contact between faces.
Are you already trying v6?
First impressions. slides?
hi stef excuses the delay for the answer, however I have had two occasions to try it, in the express version, from the point of view cad news are mainly linked to the direct integration with the pdm for which who works in v5 has no problems of familiarity, things change from a point of view of work flow that is regulated by the pdm, so the mania we of all to move renominating posiszione to the other
You have to forget to have an installation on a signola machine, there is the concept of server and cliant, so you will have to have the two installations (as a cinfondo happens to the azinde that want to implement a pdm).
the pdm part is all graphics so you do not have to deal with sterile views and almost incomplete messages hidden under nested windows. the information is all visuli, you can trace objects in the simple db by descriptive name, but above all searches for "form", and who work with an extended pdm in multiple nations, you can realize that a search for ninth of an object could be almost impossible.
then there are all collaborative design tools that allow me to share as well as the simple desktop, also the portion of project on which it operates that it has been appropriately filtered, without need, to create temporary subaxis.
the big difference between v5 and v6 perhaps will be found in the management of the assemblies, because as file entities "spark", so you can reorganize release the data of a project without being linked to the structure that you are building.
