drain dryer
  • Thread starter Thread starter mtbnicola
mtbnicola
not finding answers to rigurado I ask to you by providing them:
Can I download directly outside the workplace the vacuum cleaner and compressor capacitances?
theoretically you can not download as they also contain oil residues, but there should be specific oil air separators. I use the third way let the water evaporate as much as possible and the remaining disposes it together with the emulsions of the machines, you also have to see the quantities in play, mine is a small plant and I do not produce much condensation.
thanks for the answers.
the manual I don't have it, since the dryer was purchased used in the seen and liked form, I asked explanations to a compressor installer but I had not been given certain answers.
the manual I do not have it,as the dryer was purchased used in the form seen and liked, I asked explanations to an installer of compressors but had not been given safe information.
with the visa and liked ... we also give the manuals since the machine must be certified there, and there must also be the declaration of conformity signed.. . otherwise it is an uncertified abusive plant not to norm etc.
if there is the brand above the compressor it is called and you ask copy documentation (unless it has failed).
:biggrin:
