variable section beams
  • Thread starter Thread starter zon1991
zon1991
As I have to draw a variable section beam, and not finding it in the revit library I decided to build it. the problem that arises and that when I build it then I cannot change the parameters, here I entrusted myself to you to find a solution to my problem.
Make us understand how you built it... :confused:
Sorry... I used modeled in-place, and once I go to load the object in my project, it does not allow me to change the base and height of the beam.
is not consistent what you claim: "modeling" in place means drawing the object directly into the project: How can you upload it? ?
if you have used a family, you must assign the parameters of distance (length, height, etc.) and material to the object (trave). Once loaded into the project, you can change the size directly from the properties of the type (object), selecting it in the project.
Unless you have assigned parameters, for changes, you must return to "edit" mode (both in the family without parameters or in place modeling) and change the object. if it is a family (without parameters), you must recharge it in the project after having changed it
I apologized wrongly, I went on families and I made them new, once I went on solid, union and I created my beam with double base and height. My problem arises when I go to the properties and does not give me the possibility to change the length and height of the beam in the initial and final part. You know how I can solve my problem?
would be the case that you put a couple of pictures and the rfa file to see where you are wrong.
according to me you have created the artifact and you have quoted it without parameterizing the quotas
so when you load that is
see the central/final part of the first message, in this discussion:
http://www.cad3d.it/forum1/showthread.php?t=96&highlight=recuperata
