automatically duplicate paper space views in the model
jim78b
how do I generate in car matic perspective views and not in the space model?I have autocad mechanical use the amdwgview command but it only does it in the layout!!
first ask how to make views not in model space and in the next sentence you complain that the command generates views only in the layout! I didn't realize you had to do...:confused:
Sorry I was in a hurry, I would like to create various views from a single piece made in 3d except in the model space and not in that paper
I am in the model space and I have an object in 3d, there is the autocad mechanical command that generates in the paper space the various views of my object, the roble is to copy those views in the model space. Clear?
I still don't understand. . .
at least from the title he wrote and changed, he wants different views in the model.
@jim78b
but the command windows given in the model doesn't suit you?
then in every window change the view.
different then from what I understood. :confused:
but do you want to "duplicate" in the model the type of views exactly how they are in paper space?
the problem is that the customer wants the cartilage in the model space and so I can't make windows in the cartilage tell me? So there is no way to copy the paper space content in that model?
you could generate polygonal viewports in the model space I would have solved
see if you like the command esportlayoutof course depends on the version you have of the program.
Now I get it! the same problem you have with inventor dwgs... tested with a simple "copy-paste"? or, if you create a window in the layout around the 2d view and use space changer works?
Yes that command works but export everything to the layout!!io ho mechanical 2008 English
