RS4
That's why the file was so ruined... because it pulverizes the maximum closing tolerance of surfaces with v4 and 0.01mm aime:biggrin:the original file comes from catia v4
I set the toll to 0.01 (like the original)That's why the file was so ruined... because it pulverizes the maximum closing tolerance of surfaces with v4 and 0.01mm aime:biggrin:
I'm sorry if I only answer now, but I couldn't.I wanted to answer you on this point, I made the example of creating the circle out of the origins (what you call a two-dimensional system in the center of the sketch) on purpose, I know that you can create the circle directly starting from the zero of the sketch axis and that there are so many predetermined forms, I just wanted to say that in many cases you will have to center the hole on the basis perhaps to other objects and become them can macchinoso with the tools v5. But instead what is wrong is me because every program has a way of working and in fact I wanted to understand that of catia and with your explanation I begin to understand it. that of the double click on the button command I did not know in fact it became frustrating every time having to select quota for each line that I had to quote haha! instead on the explanation of the profile command I already knew thanks to a tutorial of youtube. Greetings
to view the line of do txdx center on the dotted frame, then select properties\viste and check lines of center and axes. if you do it in tools\options for defolul your views will always be created in the same way.I was referring to what you see in the image, in solidworks the view of the development of the piece has two lines and each a note with the characteristics instead on catia v5 does not show the central lines of the folds and not even a note of its features more does not make sense to quote those lines because it does not serve for live realization! how can I do in cay??? the only thing that comes to mind and that I have seen on a tutorial is to create halfway lines between the fold lines and then to quote them but it seems a little absurd and forced to do this!
who did it is a great!!!:biggrin: at least you do four laughs when you start catia, however you know that you have commands you can associate external icons?catià v5 has the ugliest interface between all cad.
I only attach an image.
really v4 had them even from before if I don't remember badly, but I can go wrong, then for the example you bring... well I can tell you... mah? I'm just a profiter, not the producer.apart from that I approve of the choice of some cads to look like office that I find optimized for common use commands.
That said, do you talk that you still have the menus in the working area that many times you have to move because they hinder the selection of objects?
The menus in the working area were born in 1995...make sure how long you are still.
I knew the sequence of questions, but I started the sentence wrong because I replaced the answer of stef.I don't use pdm.
On the least powerful I would not be so convinced, but that maybe they are less flexible maybe it is more accurate.not all do the same things or better only some manage to do everything (nx, catia,pro\e) while others are less 'powerful'.
thanks for the compliments but you don't need just put your head on it or bettercompliments for rs4 work. :finger:
when do you organize videotutorials for cad3d cat forum visitors? :biggrin:
I'll be the first.
Thank you very much
you see beautiful softwareI set the toll to 0.01 (like the original)
test now I have remade the file to 640 x do not remember
catia 4 also has toolsboxes in the working areas and I have always found myself wellreally v4 had them even from before if I don't remember badly, but I can go wrong, then for the example you bring... well I can tell you... mah? I'm just a profiter, not the producer.
Hello everyone
as surfaces we reach the g4 and we do not need to pass them to another parametric cad since we are already but we need to pass them to the camyou see beautiful software
but I wanted to understand the surface quality and the tangences and good I just need you to close and then feed it to other parametric cads
that closing tolerances can you have g3 tangency with curvature you get? ? ?
Bye-byeas surfaces we reach the g4 and we do not need to pass them to another parametric cad since we are already but we need to pass them to the cam
Hi.Bye-bye
but the first extension operation you did it in tangency or only in closing point 0.01, because it is not possible that iges directly you can extract without giving you connections errors, the mathematics was too ruined you understand caia gave me closing errors beyond continuity
second phase closing hole in one shot without backs ensure that quality of surface homogeneous flexos? ?
I used the base tar surfaces
You can't push yourself any further, otherwise you should replenish your patch if you set up 0.001mm to give you a right error? ?Hi.
I'm not used to magic first.
the video speaks very clear direct import directly from the rar file directly from forums, I just set the toll. first at 0.01, I launched the topology that controls me discontinuity or open zones and I closed with the same tolerance
If you don't believe I don't dare tell you
If I use that tolerance, I would have all the red (open) and blue (detachments) edges in that case if I had to use that tolerance, I would prefer to remake everything, like in any other cad.You can't push yourself any further, otherwise you should replenish your patch if you set up 0.001mm to give you a right error? ?
costs are definitely due to the fact that all packages are to be developed and maintained.there are many reasons why nx and catia cost more than other products.
one on all is the cost of r&d. (even those you mention are true, however).
think first of all that catia and nx have a core modeling proper that should be developed/maintained.
being then used in designing sophisticated things must cover the whole process, sometimes on aspects that affect very few other companies (electrical/electronic design, sophisticated composites, sophisticated caes, specialized package for automotive/aerospace) and also the "standard" part of the product has more advanced features than the mid-range (thinking surfaces... to certain aspects of top/down design... )
That doesn't mean a high is more powerful than a mid, indeed... on certain aspects of the product a mid is more productive.
What more the mids have than the highs are bullshit. Cosmetics... (for charity, important...). the beginning is:
- a high to close gaps with a mid puts us little (see nx8)
- a mid to close the gaps with a high simply can't... it doesn't have technology... He doesn't have the r&d. He doesn't have the money.
If ford had the sales volumes of auditions, then yes.I tell you for so many things, but not for what I have highlighted.
therefore, according to your reasoning:
- Should a ford cost more than one audi?
- Does a fiat cost more than a ferrari?
- a samsung tv has to cost more than a bang & oloufsen?
- a kg of barilla paste must cost more than one kg of a gragnano manufacturer?
mmhh...no fear
I've been working with the cad for a lifetime.Who did I tell you that it is less intuitive than everyone on what basis? ? ?
advanced features you noticed:biggrin: we talk about 30 years of automotive aerospace development costum with titanium aluminum materials and composite of the whole product life cycle.. more than 140 dassault modules and many other external ones from official partners .... specialized for aviation composite both as cad solutions that cam everything in a single solution i.e. catia v5 I want to remind you developed first by boeing in collaboration with dassault
has an excellent all-screen interface!!! you have the opportunity to move the icons where you want and create new ones!!!! without ever having visual problems in the working air, macros in will costumed for every need with the possibility to create also the icon with the mokamucca:finger:, steps from one module to another in an immediate way you can work hybrid and not, class surfaces with excellent fast computing capabilities even more complex
continues to make cubes in the sketch quickly with solid works, than to the rest of the automotive aerospace ..... specialist thinks catia pro/e and nx
I attach my icons see if you like most custom
I don't really agree what you say until now I'm just chatting, you know about the executives and many more chatting to hear.I've been working with the cad for a lifetime.
I come from euclid of the matra dating which was then bought by dassault to bring birth catià.
I have worked with all the cads and I guarantee that catià is the least intuitive.
Maybe you don't have my own cad experience.
If for you the image you posted represents your 'all-screen', then we are not.
catià is back years with the interface.
I wanted to remind you, maybe you missed it, that behind the new live building interfaces, draftsight, etc. there are solidworks corp operators.
this to tell you how much French programmers are evolved with interfaces.
if then solidworks stays back and cannot implement some features, it is not to blur catià.
impactxoft (module of mold) was implemented by solidworks programmers, but then aborted for obvious reasons.
you have compartment icem for your class surfaces a.
smartteam is a plm that does cag....in fact if seen what end he did.
the idea of the cloud and other you are implementing is an idea of solidworks executives.
There are so many things that you miss on your product.
ok it was normal that I answer so you can't make magic. :smile:If I use that tolerance, I would have all the red (open) and blue (detachments) edges in that case if I had to use that tolerance, I would prefer to remake everything, like in any other cad.
a small correction :impact xoft (modulo di mold) was implemented by solidworks programmers.
I personally do, I do so, it bothers me too much to put in place the detachments created by othersbut do you usually rebuild everything if not the quality and poorly 0.01mm with the classic patchwork? ?
1 thing - since you know all cad. catia is without accent (no catià).catià is back years with the interface.
