complex surface creation of a metal headset
  • Thread starter Thread starter paoanti
paoanti
I have to make the piece of the magic... for the feet is not too difficult, but for the head I honestly find myself stuck. How can I move?
use wf4
That's easy.
with a two-section blend you make the middle part and then intersect it with an offset surface of the foot.
Uh... I don't know. the problem and that after doing the offence of the foot I should connect the surfaces and I would have big problems in the part highlighted in the photo, right? I had already tried to make loffset and then to connect with a ray but it gets bad see the photo...
You're supposed to think about "pezzi."
do the dome first and then the 3 surfaces in turn arranged at 120°. when you have realized everything, use the command "join surfaces"
edit: I actually realized that as I suggested you can not make the rounded part you marked in red
:smile: it seems easy... But... :tongue: I also said, I put 2 minutes, but I'm still stuck:redface:
I don't know if I understand well... look at the annex.
made with wf4.
of course you can add missing fittings and adjust the odds that do not go.
made with wf4.
No, it's not like that. Maybe the photo doesn't make you understand how the surface is made. I'll get you some more magicians to make you better understand... .
Maybe it's a "thing" that pro-e can't do... Could other cad competitors, according to you, succeed?
I think there's no need for isdx, the functions of the foundation are more than enough.
I was waiting for them to tell me if what I did is okay.
Next time, I don't really do these things.
ehmmm.... no, we are not.... if you see the photo well the surfaces are tangent.... i.e. it is made differently, more complex, more fine. Maybe with catia...
but what cat... the problem is not the...
in the annex there is an image of the headphone: take into account that for how I have realized it is possible to edit and update in a few seconds all the dimensions, the angles of the domes and the rays of the semilune since I have not managed to make it identical to that in the photo
it is a surface of which you should then make the offset of the desired thickness and solidify
if to someone can be useful I can post the file made with wf2 (without isdx)
