fori in cilindro
  • Thread starter Thread starter sisaxix
sisaxix
Hello, everyone. As time passes, I am becoming increasingly familiar with inventor, and today a dilemma arises: I want to make a threaded hole in the side of a cylinder. Can someone recommend me how to do it?
Thank you!:confused:
thank you very much for the answers, but in the video the hole is not threaded. I try to do as you say, then I tell you. Hello and thank you!!! (if you have other communication solutions)
to the video solution you can apply the thread later, via the thread command.
instead of creating a circle and then extruding it in negative you have to create a point then use the "hole" command and you can choose whether it has to be threaded, normal or with lamatura.
Good luck bye!! !
in fact, but it was subtent. and can't you choose if the hole is passing or threaded? the procedure is the same. I posted that video that was the first one that came under my hand.. then looking at those pages of youtube there are all video tutorials, just search. . .
Marco:smile:
It is not a jar of jam that after you have taken a spoon you have to close the lid:biggrin:
