copy together and parts by changing the name
  • Thread starter Thread starter xxfast
xxfast
Hello.
use sw 2009.
I currently need to create copies of some assemblies and then edit parts within them.
once I copy the axieme I go to asegnate the new code and then I open it and modify the internal parts that interest me.
the problem is that once the change is made if I change the name of the part I have changed, when I open the sw axieme does not find me the aforementioned renamed part.
in my pc, instead, sw2011 asks me to tell him the position of the part to which I changed the name, at the opening of the axieme.
Do I have to make special settings?
or, how should I behave if I want to make a copy of an existing set and then rename it with another code and change the parts without having to prosecute me?
you have different settings in de cad. go to options or check what's different. should be in the general tab to be set solicited under the heading "in case of reconstruction errors".
just compare the options of the two pcs.
I, I would pack & go and rename everything there.
Okay, thanks, guys.
I will try to check the settings in the general menu.
I have to take a look at pack & go, which for me is a new function never experienced.
hi si pack & go takes away every problem.
just open the part or assembling on swx 2011 and from the file menu -> pack & go... you can change directory, name, also duplicate tables or any analysis results.
to stem the problem that you have using your current way of duplication where you have renamed the components of and the assieme, I presume you have the problem only when opening a set that does not find the renamed parts. in this case you find yourself in the tree of the composts a part where the icon is gray. select it and either by right mouse button or by menu, replace -> and tap the resources of the pc until you find the part you have renamed, then save the axieme and you will see that it no longer gives you trouble.
Hi. .
Hi. .
Okay, thank you, 1000. You've been very helpful.
Monday I come back to work from the sw 2009 post and I will fix the files that in the axieme are not loaded with the "Icon System" .
As for the pack & go function, I gave him an eyeball and I must say that it is very useful. next time I will use this function to copy my files.
Thank you. :finger:
