problema con pro/engineer wildfire 3.0
  • Thread starter Thread starter sf_1988
sf_1988
Hello everyone are new to this forum, I have a problem with proe 3.0. until recently it worked perfectly now is giving me the following problems:
1- when on any created file precedes I double-click to open it opens the program and exits a window where it asks me: no written permission. . .choose another boot directory for trail cretion.
2- when launching the program directly from the desktop opens the program and exits a window with writing: licenses request failed for feature proe_ddity: -9:
in both cases closing the windows also closes the program...someone can help me? Thank you! !
I see that it is your first message ... you presented yourself in the appropriate section to other users?
for writing trail files, it is a classic message that appears when the writing folder was created by the machine administrator and alerts the program as a standard user (and then you do not have the writing privileges for that folder).
The other mistake is a license problem, did you make any changes?
What's the section where I have to introduce myself?
cmq about the second mistake doesn't seem to have changed anything about the first error how can I solve it?
for presentations here...http://www.cad3d.it/forum1/showthread.php?t=463for the first error:
you should enter as a system administrator and authorize the use of the folder to standard users;
Alternatively, from standard user create a new folder and indicate it in the option trail_dir of the config.pro
for the second error:
enters the subdirectory bin present in the installation directory and starts the ptcstatus.bat file
opens a system window as from attached image.
let us know what the outcome of this verification is and we will see to understand where the problem is
ok now nn I have the computer underhand as soon as I can I let you know!!! Thank you.
hi I made the steps you told me...I created the trail_dir folder and indicating the path I exit again the window licensed required etc....
by clicking on the ptcstatus file opens the window you had indicated to me, but it closes immediately by itself
therefore the problem of the trail_dir seems solved.
You obviously have a licensing problem.
is it installed locally or as a license server?
try to launch the ptcsetup.bat from the bin folder (the same as above), at some point you will find a window in which the type of license used is indicated.
You probably have a priority issue of network cards.
go to start > run, type regedit and press forward.
in the system log search for the networkcards item (use the tool finds), here you will have many folders for each network card of your pc, rename the folders and from 10 to that related to the network card on which you have the license, 20, 30, 40 for others.
true prof.
time ago I indicated the procedure to solve this problem at the following post:
http://www.cad3d.it/forum1/showpost.php?p=189216&postcount=9
Have you tried to contact ptc assistance?
Unfortunately I do not know the code of that error and going for attempts means losing a lot of time.
I would first reinstall the license from ptcsetup.bat... but, it is right to make an attempt.
Good evening
I have the same problem
You could tell me step by step how to do it.
Good evening
is explained very well on the previous page in post #4
I have tried all the pro config present in the various proe folders, but I do not find trail dir
trail_dir is a voice to be inserted in the config.pro
e.g.trail_dir c:\proe\trailensuring that c:\proe\trail exists and has a writing permit for the user who uses proes
