change multiple parts together
  • Thread starter Thread starter Geppetto82
Geppetto82
I searched on the forum and on the online guide (I found thishttp://help.solidworks.com/2011/italian/solidworks/sldworks/legacyhelp/sldworks/assembly2/editing_a_part_in_an_assembly.htm) but I found only the modification of a single part and not more parts.
I am in a set: I want to make a hole passing through the various parts. But I have to change the part, that is, if I open it, I have to see the change.
I found 2 roads but are not the right ones:
1. dx key on each part, edit part and so on for each part (too slow and risk to wrong)
2. sketch, cut extruded in the axieme: I see the hole passing but if I open the single part no!
I know but I don't fix it. .
Hello everyone
geppetto82
Hello everyone
geppetto82
the road n°1 is the one used normally since a piece must be in relation to a second (one at a time) otherwise you would design the machines in 10 seconds knowing already everything goes with everything.
the road n°2 you have to activate propagation function to the parts (but not wait for magic) is a work done together and as such it is and remains even if reported in the parts. (see Annex)
what I was looking for!!!! !
Thank you very much mechanicalmg!
method 3 = top down, where in addition to holes change anything from top to bottom....
