joshua
can you set inv so that each save automatically generates its .dwf file?
I think that with i-logic you can do it... let's say that i-logic is a real world apart and it would be very interesting to explore it.can you set inv so that each save automatically generates its .dwf file?
thanks to all for info.try reading this 3ad, same your request but for dxf. as indicated if you are looking for in the help:
http://www.cad3d.it/forum1/showthread.php?t=25897&highlight=esportazionef1 > programming guide (bees) > cut-and-paste sample code > export iges/step/dwf/dwg/dxf/pdf using translatoraddin (toward)
you will find the code to copy also for your case.
ehm[...]f1 > programming guide (bees) > cut-and-paste sample code > export iges/step/dwf/dwg/dxf/pdf using translatoraddin (toward)
I mean, like the most unexpected and less read sections there are::hahahahah:hahahahah:hahahahahahto the forum gurus: wishing to consolidate/resume once and for all instructions to copy macros in the various template files etc., then you could create a "highlight" section where, without needing to repeat everything or to send back to the links every time, then users can go to see? a little like it happens with "present here" and " forum rules", I mean... :tongue:
Is there a manual inv, even not italic, that gives an infarination on the subject?I mean, like the most unexpected and less read sections there are::hahahahah:hahahahah:hahahahahahf course I'm joking,I'm sure to say your idea:finger:
