Dexster
hello to all
I'd like a little help. to calculate the force necessary to lift a body as from attached box. . .
practically is an arm with an applied load on the tip that rises and lowers through a pneumatic cylinder.
the data I know is
weight to be raised in my example 100 kg but can be also 50 kg
the cylinder (allocation 100)
cylinder drive bar (8)
distance between the rotation pin and the cylinter connection point (distance a)
distance between the cylinder connection point and loading point (distance b) [I do not indict them because I practically do not know them yet sincerely)
the cylinder is mounted in a sloping position but the axis of the stem is hypothetically 50/60.
I never studied mechanics
to know before
I thank in advance anyone who can help me or explain me to make me understand. .
the data I know is
