texture blurred in working environment. help!
  • Thread starter Thread starter edo_ita
edo_ita
Hey, guys.
I would have a problem probably trivial... but it stuck my job.
the problem is this:
work with 3dstudio max and v ray as a rendering engine: I have a very large plan on which I apply a texture (a jpg of discreet quality) . why do I see the texture extremely blurred in the working environment and instead of good quality in rendering?
I can't align this texture with other objects placed above the floor...just because so blurred that it is impossible to distinguish details and align it.
I can't understand why! !
Thank you! :confused::confused
Thanks for the answer. I found but I have cmq a problem.
set everything to the maximum, reboot 3dstudio but the settings return those of before. How come?
no, if you change the window display settings, and restart max settings are saved.
you can save the file and then close max from the task maganer..ciao
