printing press
  • Thread starter Thread starter Giotto
Giotto
hi to all:smile:,I created an image thanks to photoshop, whose proportions are 1920 x 1080 pixels.The problem I pose is the following,I turned the images into jpeg and then I tried to print them,in a4 (cross horizontal),but here happens a small problem,the images are hurt,that is, the side writings are cut, so I try to put another type of layout, always say to the whole page , thank you in advance. :smile::smile:
hi the first problem is that the a4 does not have the same proportions you used, in fact you used a different length/height ratio.... you used a hd format, while the a4 has a less elongated ratio, (mm 297x210)
In fact if you try to open a new file in ps and give it the size of your imamgine, then you paste an image in a4 format you immediately realize the difference, I suggest you prepare the image of the size of your print out...if you stamnpi on a3 prepare for a3.. and so on.....I think the problem is that... hello let me know if you solve... .
thank you for your answer I solved my problem.xd
in case the image had already been created with proportions other than those for an a4, I would recommend in resize applying the most suitable reduction algorithm and before opening the printing management window.
