ball and distinct base.
  • Thread starter Thread starter Pierobia
Pierobia
Good evening,
I wanted to ask if it's possible and if it's how to do it, to "ball" with progressive numbering even the equal parts and then to have them in the distinct base not grouped as quantity but all separate.
Good evening,
you should create equal parts all different, i.e. assign a different file name for each replicated object, oppue assign the numbering manually.
The thing you have to do doesn't seem very logical, but I'm curious to know what you need.
the thing is to have also the reference of the position of the part inside the assembly scheme, as is done in the part-lists. e.g. in the electronic field even if the resistors are of equal value each have an electrical position (r1, r2, r3 etc.) that diversifies them and identifies them in the schematic. I thought you could do it in the cat.
you just need to change the name to the instance (sel. the tastdx part property, product table "istance" if your menu is in English, or it seems to me "repetition in Italian), the latter even if you change the particular associate, does not change in the definition of the axieme.
at this point you can assign the ball by changing assign the numbering according to the name of the instance (instruments\options\meccanical design\drafting\ table "annotations")
Thank you so much, now I try.
Good evening,
Hi, I don't know if it's the right way to ask a question, but I try:
when I insert the balls on the dwr catia v5 of defaul ball with 1-2-3-4... I would need the numbering instead to be 001-002-003-004....010-011-012... is it possible to set it in that sense?
