automatic properties in table - solidworks 2011
  • Thread starter Thread starter FIGOR71
FIGOR71
Hello, everyone. .
how can I put the properties into the table automatically. . .
I'll explain better.
1)- bubble - img. pos.1
if I insert in the bubble number part gives me a number... What is it?
2)- number of pieces -
Is there any way to get it inserted automatically? Where do you get the number of parts inserted in a set?
3)- weight tot.-
how can I make him calculate this value based on the mass property already inserted automatically?
I'm sure someone will give me the right answers!
thanks and good work
Hello, everyone. .
3)- weight tot.-
creating a table connected to the axieme does all this automatically and in a very simple way
pass from the properties of the single part is possible only if you impose the number of parts present; then through equations you can get the total weight.
Hello, everyone. .
3)- weight tot.-
1) the bubble should be connected to a component. I don't understand your purpose.
2) parts are divided into separate materials. the amount of the axieme/part that is stacking directly in the sheet cannot be automatically inserted with standard swx. to do this I "mark" the drawing in the printing phase with the pdm, inserting besides the quantity the commit and the date of printing.
3) simply insert a "weight" property into the prototype file to which the property is valued.
