marchionili
I have on the pc autocad 2012 but I can't use it because it is completely different from the version I used previously (autocad 2004) and I would like to change the standard graphic interface with the older one with the classic square icons around the screen. I know you can do it, but I can't. I would like to be able to work in a work environment more similar to carcad 2004 otherwise every time I have to do something I use half an hour to look for the command.
