The_Matrix
the problem is exquisitely marketing... a steel mtb doesn't buy you...My joke was about the fact that we often get lost in the fact that aluminum has a lower density.
as you rightly point out, y/rho of steel and aluminum look like, so, so much so as not to get down in details, if you do aluminum, put three times a material that weighs a third, and therefore you have the same weight.
But there's a but. steel is calculated more easily, has a fatigue limit, behaviors under various types of stress are known. is more weldable, admits smaller welding cords. Therefore, always to simplify the overwhelming, with aluminum you have to use a bigger safety factor than with steel.
This is demonstrated that aluminum is heavier than steel.
Of course, a design made by aluminum experts (aerobic case) allows to rosicare where with steel is not possible. and here is also the rare cases mentioned above.
