nicolapodda
hi to everyone, I am new to the forum and from a few weeks I have been "frugando" autocad.
I have 2 questions to ask you... (Surely for you are discounted)
I designed a dog's bunk on autocad. I did everything in 3d using solids for pillars that have 1mt height 12cm deep and 8cm wide, and for tables that have x length 13.5cm wide and 2.5cm thick. but now I'd like to get a cut list. example... I need 2 pieces of 1mt long beams, 15 2mt boards etc...
I read that it is possible to get the whole but you have to create blocks of every single material and then insert them into the drawing.
I created the pillar block from 1mt x 8 x 12. within the block editor I assigned the properties of length and height and now I can export with a table the various measures.
Now my problem arises. when I insert a 3d block and want to vary the length of the latter as I do? I tried to give an ironing action but when I go ironing instead of stretching the object moves it.
Can someone help me?
Niche
Niche
