Ivan1990
my advice is to erase only the temps in the local, move everything in the basket, restart verify that solidworks and the pc start without problems, and then eliminate them altogether, at least this procedure that I was advised during the course I did. However it should not contain anything important, and in case there is something important in general you report it before or it does not really wipe you out. I in my personal temp in window I do not touch them, as what about solidwork goes everything in the temp. for the rest a cleaning of the temps every now and then it is advisable and before you remember to close solidworks.Thank you, no, I try not to mess up:tongue:
and just for this reason apologize again if "find" the post asking for clarifications:
I've got it
c:\users\you\appdata\local\temp (2gb)c:\windows\tempo (106mb)- can I delete everything that they contain without problems or should I look for and eliminate only swx things?
- I have to worry about closing all programs or deletion first does not cause problems?
Do I have to worry about not erasing today's files or in use or not?
