Parametric_Ozzy
because maybe those who build the pieces are outside and then they need the dxf or dwg rather than the pdf.The boards yes, the dxf no!
Here, but is this the passage that I do not understand; why go compulsory to the dxf?? What do you need? I (but I think a little everyone) converts to vector 2d only to send the "sagomes" to laser cutting.
2d constructive tables quoted and "finished to perfection" you do them directly from cad 3d in a absolutely parametric way.
the beauty of these programs is that the 2d "classic" you forget it.. if I have to remake it all is time and money lost unnecessarily, not to count the cerebral agrovigliamento that pursues it.
in any case the symphony does not change. .
is always an export that does from table 2d membership to 3d no?:biggrin:
manual,semiautomatic or automatic is stess!
