the light effect does not propagate in the absence of a support, air, water or surface.look I gave you a fast file to see the problem, but I have already tried to put it in a dark dark environment pesto and with white light, me the result is that I see the body of color, but I do not see effect of the light that propagates in the environment, soppratutto that touches the other surfaces, mintra I clearly remember that in the 2010 version I could, even in 2011 before the passage to windows 7.
...:4406: aaaa well, you are liver with his hands, a nice tutorial on yt does not take it anymore nobody eh... :biggrin:@reggio, at the moment I am taken, the answer needs a little time, but I promise you that in the next days we will face the theme. :finger:
Okay, you know, I was expecting something better.the light effect does not propagate in the absence of a support, air, water or surface.
then creates a plan to make the irraggimanento "support" and uses dark environments, darker if the light is dark too.
I'll tie you up a couple of times.
as mike says, you need to adjust all the surrounding environments to see the light effect.Okay, you know, I was expecting something better.
for that you should put a light at the light source.Okay, you know, I was expecting something better.
I knew that I had a limit of 8 lights, I needed a dozen:biggrin:, I was looking for new ways, thanks for your explanations:finger:un esempio...
