draw two offset wheels
  • Thread starter Thread starter errico
errico
Hello
I'm trying to create a program so I can design two offset wheels
I managed up to a certain point...I would like to get the process automatically without having to select the object and the direction as I do!!! :confused:
(defunc c:circus ()
(setq ra (getdist "\nraggio ")
thk (getdist "\nthk:")
(setq c (getpoint "\insertion point:"))
(command "_circle" c ra)
(command "_offset" thk)
can you simply add (or remove, depends on the direction you want to take) the thickness of the ring?
in practice you have to do nothing but draw a ray circle and a ra+thk radius (or ra-thk). You don't need the offset command.
Hello
(defunc c:circus ()
(setq c (getpoint "\insertion point:"))(set pt (pollar c 00 (+ dropped tk))(command "_circle" c ra)(setq tmp (ssget "_l"))
(command "_offset" thk tmp pt "")
servito
bye
