Ing Italy
I apologized... I'd even looked at it.
true, however for 3 months drivers are ok and setting for some softwares the obligation to use nvidia instead of the intel has solved everything.returning to us, if the budget does not allow you to purchase a mobile workstation, take a consumer, but I would tell you to stay on asus or sony with vga ati, this should avoid you problems as it seems to me that they are the best consumer as care/assembly/progettation and at the same time to a normal vga, it is not schifezza with continuous change of vga for energy saving.
I found them on the site acer and immediately downloaded. I couldn't make it work, and I lost a few hours. I did so:true, however for 3 months drivers are ok and setting for some softwares the obligation to use nvidia instead of the intel has solved everything.
no, acer la evito come la peste even if I have many confirmations, as acquaintances, on the goodness of new products. my asus has accepted the updated drivers taken from the nvidia site quietly, and actually is the first time for me. all other notebooks that I had accepted only the drivers signed by their respective manufacturers.I found them on the site acer and immediately downloaded. I couldn't make it work, and I lost a few hours. I did so:
Uninstalled the original intel and nvidia drivers in temporary mode, restarted, installed the intel drivers and then the nvidia.
In this way the card no longer works properly and you can't even set the native resolution of the display.
if you reverse the installation order the intel card works correctly, while the nvidia is not recognized with consequent error in peripheral management.
Do you have an acer? Did you get him to take the new drivers?
I have to tell you that acer has improved a lot, this notebook, apart from this problem, is done pretty well and turns well.no, acer la evito come la peste even if I have many confirmations, as acquaintances, on the goodness of new products. my asus has accepted the updated drivers taken from the nvidia site quietly, and actually is the first time for me. all other notebooks that I had accepted only the drivers signed by their respective manufacturers.
no well I asked in the forum just because I think the testimonies are valid and so I thank all those who like you have given me some tips in that sense.Mah mah I bought it about nine months ago and it's going great, it's one of the black and serious ones, and precisely...
hp pavillon dv7
intel core i5-480m from 2.66 ghz if I remember well
hd 500 gb - ram 4 gb - display 17" wide
windows 7 home premium
webcam with integrated microphone
card with ati card 6550 1gb
and it seems to me to use it so much, this is my testimony for what can be worth.
