command mode size
  • Thread starter Thread starter Samuel100thw
Samuel100thw
Hello, when I used the previous versions of 2011 I could cut multiple lines intersected between them by selecting them together, while now if I have more lines to cut at the moment when I have to cut them you have to go to act on every single line.. . otherwise he cuts me wrong. Why? ? Can someone solve the problem? ..I apologize if I wasn't clear but in autocad it is easier to show you the things that explain to you: )
Thank you! !
edgemode is already zero. .
Thanks anyway!
I try to be more precise. .
1-execute the command size
2-Select the elements to cut (e.g. a series of crossed rows)
3-
4-hour I go to cut the elements
5-problem! If at this point I select more things, I cut them wrongly, if instead I select one by one it's okay
with previous versions the problem did not exist.. .that is, I could, when I went to cut, cut more elements together using the command sending clik of the mouse.. .
