import solids from autocad, on an artlantis design during processing
  • Thread starter Thread starter tatekan
tatekan
Hello everyone, I'm working on a project, and I started applying the various textures and objects with arlantis studio 3. the three-dimensional model was made with autocad 2010.
I need to add new elements from autocad to artlantis. of course the file is the same of origin, with the addition of some objects and no modification compared to the open file with artlntis.
I thought it would be enough the command "unisci geometric figures from file"....., unfortunately it was not so, the design remains unchanged. Could you please help me?
nb thought that a solution could be to isolate the elements into individual files, open them with artlantis, and turn them into objects...., but it seems too laborious...., help :-)
check that the units are the same in both files.
did you even try to do the opposite? or import everything in autocad?
the units of measurement are the same...., but how is the procedure therefore correct?
One last thing, what's the point of importing everything into autocad? the original file of autocad that served me as a base to work with artlantis I already have..., what can I do as an alternative?
