recover dwg files
  • Thread starter Thread starter gerardo25
gerardo25
Hi, everybody, I'll put my problem in a short time.
I have a dwg file called "graphics" on which I had a complete project.
today a new practitioner who has to make a catastral card takes that project and makes it a copy and draws us on erasing then everything.
now the copy that has made has not gone to good end and therefore has worked on the real project and now in the file there is only a poor tab catastral.
Now I wonder is it possible to go back inside that dwg file?
Please help me.
see if you find a .bak file generated by autocad on the date before saving and restore it.
No bak.
alternative, besides remake the project again?
Is it not possible to go back on the drawing board above the project?
No backups? :tongue:
if you have closed the dwg there is no more possibility to cancel the changes, you only have this procedure:
- search in the folder set for auto save files (options\file) .bak or .sv$ file with a name resembling "graphics", of the type "Music_7122.bak" or "grafici_1_1_6334.sv$" - select the most recent
- change extension in .dwg
- Try to open it.
- Please.
you can also do a search in all disks including hidden folders, of the "graphic" file
copy files with .bak or .sv$ > extension of 1kb in a folder and according to the dates you rename them.
should jump out
Thank you very much! ;)
I solved with recuva
it recovered all deleted files from pc (including backup) and among them I found all the rescue files dwl, bak and sv$
I renamed in dwg and among these was the project,
thank you for the advice
