search free cad and edrawings
jim78b
that you know with edrawings I could edit dwg drawings and also make blocks? Maybe the pro version?
I look for a free guy who has the setting like me10 of the cocreate ..that is he has not the blocks but parts... .
thanks good day:redface:
I don't know what to say!
He thinks there's still someone who has me but doesn't use the parts!
Try to see draftsight. It's free.
the blocks create them. then change them with a double click, attack you with the snaps to the geometry below and exit the edit by saving.
I used it propio yesterday on a file that sent me
p.s. if I had to go back to work in 2d that way I think I would end up in black chronicle after an airplane made a massacre of innocent people on the street... :redface:
We have to admit, it's a temperacaxxi, but often useful!
Thank you marcof!
:biggrin:
so the way to work in 2d better?
The way I prefer is not to work on it, and when I have to do it by hand with paper and pencil before leaving with the 3d... thinking in 2d is against nature, we do not live in "flatland". :wink:
said that, did you try draftsight yes or no?
p.s. you must quote the messages of your interlocutors, otherwise you do not understand to those who answer
I thought I was having trouble printing pdf
edrawing is not a cad, or at least not born to be, then with the free version you do not have many options... and the paid version does not seem so "economic"... :rolleyes:
I don't want you looking here, trying to, try one, try another, you're not getting confused with ideas anymore...
p-h
I with draftsight printed pdfs without problem. will depend on the software you use to make pdfs.
Frankly, I don't know what you're looking for. first ask if a viewer as edrawing allows to edit the blocks of dwg:eek:, now laments (maybe... seems to me) of problems to print pdf (which will then depend on the virtual printer you use and not the cad).
few but well confused ideas? :confused:
p.s. quotating messages as it should seem difficult to you; no cad :rolleyes:
You're right! I was attracted to the way for example of solid works when you put on the table, I liked it as a 2d system... something like that?
when they ask you to "quote" a message to understand who you are answering, you must press the "quote" button that you find on the bottom right of the message you want to answer :mixed: , as I have answered you now appears the panel of the one I have answered (in this case you )
:confused::confused
but what are you talking about, of grace??
we started from local editable blocks to get to the table of solidworks, which is an operation that is made from a 3d model! decide what the topic of this thread is for pleasure.
If you want to use the swx 2d and however the constraints, I think you have no choice but to draw in the table setting or in the swx sketch, with all the limits of a 2d that is not designed to work as the 2d autocad.
I read that the 2d free solidedge (parameter with constraints etc.) you don't like, draftsight still doesn't understand what I have for you not go etc.:confused:
I asked you twice to correctly quote the messages, but I think you're amusing; Maybe I had to order it?
I can strive to interpret and translate current messages in Italian without punctuation like yours, but if I have to go back to a page to understand (as long threads can be found) to whom you turn then I turn the spheres, so here I close... I pass the ball to those who want to commit more than I did to try to understand what you need.
:confused::confused
He doesn't even know... that's the real problem. .
