unrecognized jpg image during insertion
  • Thread starter Thread starter Xenor84
Xenor84
Hello, everyone! It is from today that I try to insert within a dwg file an image in jpg format of a cathartic map to draw on it, but I can't! every time I try to upload it to the end I always report "an invalid or unsupported dgn file has been selected"......mah!!! What does that mean? ?
Please tell me what I can do... thank you in advance!
..an invalid or unsupported dgn file
I suppose the image extension is not jpg or bmp.
if it is so loaded in xnview (or other photo program) and save it in jpg, you will see that then there will be no problem.
if you do not see the file extension go to folder options, views, and enable the file extension display.
:smile:
thank you so much roberto, but the image gives me already saved in jpg! can I save it in other format maybe?? Oh, my God, this never happened to me...
What version do you use of autocad?
try to attach the file I make an attempt......
I'll send it right away.... thank you very much! I use autocad 2010
the file works. Surely you have something on autocad. is your version updated?
command: _pdfattach
and enter the pdf directly
maybe autocad 2010 had not yet the possibility to use pdf.
However with autocad 2012 I use the naked and raw pdf but if I try to rotate it sometimes disappears. :frown:
We're overlaid. .
