message about the representation of the level of detail
  • Thread starter Thread starter Alby189
Alby189
Good morning, everyone!
Today in the office a doubt arises: to my colleague working with inv2012, a window comes out with a message related to the representation of the level of detail. . I use the same system but never happened to me.
Also in the file concerned the tree top name on the left is renamed, I attach two images of the message and tree.
another anomaly of this file is the failure to update in the axieme:
in essence he works in a set, in turn contained in another general set b, if he changes a particular in the axieme a, the change is not seen in the axieme b (the updated icon is turned off..). to see the change must close and reopen the axieme b.
settings are set as mine, and I don't have these problems.
suggestions??? Thank you! !
It's a normal message that appears when you suppress a component in the main detail level and then you go to save. :wink:
in fact the message asks to give a name to your level of detail you created (and that inventor has already created as you see in your image 2)
You obviously see it for the first time because you've never happened to suppress it in the main level.
:smile:
(written phrase : however you are a little ot, perhaps it would be right to open a specific discussion. )
Thank you for the answer!
Now it's all clear, using the 2012 version recently I didn't know the level of detail. . .
I personally never use suppression, for that I never happened, usually hid and discovered, but never suppress anything.
Instead my colleague used it, so no problem! In fact, with the occasion I also saw the levels of detail and I have already identified what may be the ocmodities applied to my work.
p.s.
I wrote in the topic of 2012 to avoid opening others, I thought I did what was good and right... Sorry!
p.s.
no problem, it is preferable to open a discusion for a specific subject, so that those with a similar problem, can find it with the "search".
if instead our posts are immersed in a discussion that speaks of other, they are dispersed...:smile:
relative to welding processes once suppressed in the detail level remain suppressed even in the main level, as can be resolved without hiding them in the table.. .
