blacklily83
I have a problem with external references.
I'm working on a file that I didn't create with autocad, but it comes from a conversion, I'm so with about a thousand external references that I should break.
with the manual procedure, i.e. insert > external references > detachments I can only detach one at a time or at most a ten, if I select more autocad blocks.
Does anyone know if there is a command that allows me to detach all references at once? (autocad 2011 or mechanical 2010)
Thank you very much:
