afullo
Hello, everyone.
I am doing the master thesis in mathematics on t-spline, and as an application part I showed some uses of this recent tool in rhino. But what seemed to me to understand the software is that it allows to work with them, but it leaves a bit the mathematical aspect of the matter, focusing more than anything on the practical one, useful for those with the program must realize something concrete. in particular, to optimally connect the theory with the application, I would like to make visible or however to have information on the t-mesh of a given t-spline surface, with the set of nodes intended as pairs of parameters (http://wwwlb.aub.edu.lb/~anasri/tspline.pdf) as well as that of the control points already visible from the standard display. that you know you can do? I own rhino 4, but in case, if available, I could safely download a version of evaluation of the 5 (for the use that I carry out I do not need a commercial version, I just need proof).
thanks in advance and greetings.
fabio
fabio
