missing commands in the working area
  • Thread starter Thread starter loky121266
loky121266
hi to all, I kindly ask help to find commands on autocad 2011 3d that are present in the area of work 2d. the command to set the color of the lines I do (which in the working area 2d is the color, line thickness and line type), and the command carries forward/port back. Can you help me? Thank you.
the commands of the 2d are, of course all, in the 3d.
I don't understand what you mean...
However, personally to change current color I use the property curtain windows, where there is also line type, thickness etc. etc.
the front/back is the draworder or _draworder command (if you have the autocad in Italian).
or, better yet, select the object and right mouse button.
If you didn't do strange customizations is there.
You don't understand the concept of work area I think. the working area is a preset or built environment according to certain requirements. The fact that you don't see a command icon in a work area doesn't mean that that command doesn't work in that area.
you just have to customize your area as you feel appropriate.
Meanwhile, thank you for the answer. what I mean is that of the attached photo "work area 2d", which I do not find in the 3d work area.
Yeah, I figured. the fact is that I can't find where to add it, if I do right clik on the top bar opens the possibility to add but they are all flagged............... I can't find the command. The work area, as you can see, I've customized it for what can serve me, but I can't find it. Thanks again.
command iupers
in the list of groups you find "start - properties", drag it to "start - 3d" which you find in the list of tabs.
I don't know what to say...... if not thank you very much.
I make the builder/small businessman, if one day you will need advice, whistle. another question:
but how do you know all these written commands? Is there a manual where they are written? Among other things I am a multitude and I know of it (with what you posted me) 3/4. I am of an infinite utility. Thanks again.
I make the builder/small businessman, if one day you will need advice, whistle... .
prego! va bene!
...but how do you know all these written commands? Is there a manual where they are written? Among other things I am a multitude and I know of it (with what you posted me) 3/4. I am of an infinite utility. Thanks again.
working with us every day for years leads you to a greater knowledge of the program (at least it is presumed :biggrin: as if you do not have the will to expand that knowledge you remain limited).
there is the online guide of the autodesk:
http://exchange.autodesk.com/autocad/ita/helpthen to document the network is full of tutorials.
