post processor selca 3045 machining strategist
  • Thread starter Thread starter Strategist
Strategist
Hello everyone, I am new to this forum and I am a cad-cam designer, like many of you, I think.
I would need to post-process for a selca-3045 machine.
as a utility machining strategist of the real.
I would currently have the .cfg file of the selca-3045 but for visi.
Does any of you know how to convert it to the strategist?
or, even better, does anyone have the post-processor for the strategist?
I thank in advance who can help me.
hi, sure that can not be used.. ? true - visi are not the same entity. . ?
I'm sorry if I ask you, you could send me the cfg for selca 3045 per visi. ?
Thanks anyway,
I cordially greet you, stefano.
Hello I'm also new to this forum, could you send me the cfg of the seca 3045 for faces you have?
if you can send me to the following address: katia-renato@libero.itThank you in advance, bye.
hello perhaps now you have already solved your problem, however the post of machining rhinestones are all "open" and configurable at your liking , if you need I have the selca 3045 , the 4000 , ecs , fidia and hidenhain 530 available , all configured for machine 3 axes xy axis tool loaded in z , however you're a second to configure them otherwise just know where to go
I just arrived in this forum as well and I am looking as many of you post cfg selca 4040 but for real visi.
onlycam could you send me the cfg for 4040 in your possession to my address gia.brz@gmail.com?
I'm sorry but true machining strategist is different from visi, I have post processor files in reg format, they are files that add or change information on the windows registry I'm sorry the house and the same but softwere are different.
Thanks anyway,
I managed to have a 3045 selca cfg that I hope will do the same.
I would need a hand, I have a cfg file for selca 3045, which I use it to process on s1200.when I genero the program comes out o1 in the first row.
where can I edit on the file in macrolinguaggio cfg so as to tell him that instead of origin or I create origin t1??( the sel1200 uses as origins from t0 to t9)
Hello seppa84,
I am not very experienced, but I can try to turn your cfg to my colleague who has already edited my cfg once for a similar problem (in my case I had to generate the program with o1 instead of t1) and see that it comes out.
I leave you my address gia.brz(at)gmail.com
Hello seppa84,
Sorry I'm new to the forum but I'd need the post processor for the selca 3045 to run with power ml of the delcam
thank you very much to all those who want me to answer
hello to all, are looking for selca rapid post processor for machining strategist 6.1. Can anyone help me? Thank you so much! My email address is gereginzeratlibero.it
e' gradita la presentation, especially before posting a request for help.
I deleted @ to avoid spam at your mailbox.
Hi, if you still have it, you could send me the postp of the visi thanks. .
Could you pass me the post [Bleep] if it's not a disorder? Thank you very much
- - - updated - - - -
Hey, if you still got it, you could send me the [bleep] post. .
If you can also me, you guys would do me a big favor, :wink:
Hello everyone, does anyone have a post processor for selca 3045 for visi to send me?
email: giampaolo.freddi15[@]gmail.com.
