multiplication of sheets
  • Thread starter Thread starter Nicken
Nicken
Hey, guys.
I got something weird yesterday.
I created a simple sheet metal processing (4 folds) with some hole and a 45° cut in the head.
I saved the part, I reopened it later and in the featuremanager I belonged two plates and consequently two "flat repetition". I closed the reopened file... and the plates were 3.
Does anyone know what wrong :biggrin: is it?!? !
I have solidworks 2012 sp. 2 - 64bit
Hey, guys.
Was there any housenova nearby?:biggrin:
I never happened, but I haven't installed 2012 yet.. .
I have swx 2012 sp.2 if you want to post the file...I give an eye.
do you get the sheet function from a single sketch or are 3/4 segments?
I never even had this version.
instead of the multiplication of bread, now the multiplication of the sheets is implemented!!! :biggrin:
I've never heard of this.
I attach the part file... in the first configuration (default) you will find the long list of sheets:biggrin:
no, it is not a list of sheets, it is a long list of flat repetitions and sheet functions which is not exactly the same thing.
Note the image, in the list there is only one body for each configuration.
hi mike... you're right.. I'm badly expressed with the sheet list;) it's plate functions....but why did they come out?!?! Where did I get wrong?!? !
Leave the world as your own, you erased bodies, configured... mirrored and so on, they're "sfridi" that stay around...
I personally avoid configurations in the sheets, especially if multibody (which I do not use because they are unreliable).
:smile:
mike, so you tell me it's correct that there are "sweet"...
personally I don't use the configuration in the sheets... but I do more and more files.... even because they are easier to manage... and even the tables are easier to create. ..without having to call the configuration every time etc....
This time I tried to see what happened....and I found out...but leave the old road to the new...you know what you leave but not what you find;)
I have the nicken file... sincerely I have in a configuration 1 sheet to m, and in the second the same sheet mirrored.... I do not see strange multiplications in any other or.o
Amazing. ..looks the mike images....they are like my...in the default configuration multiple sheet functions appear.
already I saw, even to me it gave that image (only the image) just opened, then ctrl-q and it has adjusted
open...reconstruct and disappear excess sheet functions.
If you save...close and then reopen... reappear?!? !
I opened your file. and there was a metal cable in the default configuration and one in the mirror configuration.
I saved.
I reopened the file...in default configuration everything ok, I passed in mirror... everything ok...I went back to default...and here appears another sheet function under that already present. I did crtl+q... but nothing to do... I was left.
now I am downloading the sp3 .. which released the day of pasquetta. We see if they have changed something about this problem.
you have selected.... and also I can not even change the settings on this part... is in the screed
