d3dac
Hello.
I designed a plant in autocad and drew it in scale 1:1, when I go to enlarge the scale of the map of 1.5 the quotas I made are no longer found naturally.
The question is how do I scale quotas? I tried in "quota sts" to change the scale factor, but nn I can understand which value is the correct one.
I thought this: if two-wheel drive the drawing, the odds must be scaled by 0.5, so if you run 1.5 the drawing, I will have to scale by 1/1.5 the odds, right?
