PICO
Hey, guys, who knows if anyone can make me clear.
in office use laserscanner leica hds6000 with its cyclone software and the plug-in of autocad clowdworks.
I make reliefs in the yard of a building and then design facade coverings.
so far the quickest system for me was to use cyclone to clean the cloud of points and then switch to autocad and redesign everything "calcandola" to pull out prospects and plants. I just have a simple 2d as a relief in most cases.
in more complex cases (daunted buildings) I used the solid works, which egregiamente manages to open the cloud of points, possibly transform it into mesh and do all the sections you want. his problem is that he is very slow in this job. everything is relative, but in my work it weighs.
a cloud to be transformed into mesh takes several minutes.
(consider that we talk about walls and therefore are not complex surfaces).
I may also not pass from mesh and work directly on the cloud of points by rebuilding the solid of the walls, but in this case the saving of the file is heavy (more than that of mesh) and the display of the little points (when you approach become impalpable and you struggle to distinguish them).
I tried the rapidform and I was surprised at the speed of creating the mesh (actual) and the practicality of "affection" in sections and the creation of maximum bulking plans.
the problem is then the passage of the file from rapidform to solidworks.
compatible formats between the two are .obj, -ply, .stl, .step , .igs.
in stl I find myself with a file type "image" not dissectable and I do nothing
in igs I find myself with an empty file
in step gives me error
I remain obj and ply, but in both cases I find myself only with a mesh and I lose all the polylines and the reference plans that I had created in rapidform.. .
Is there a way to keep them?
or to speed up the mesh creation of solidworks? (I already have the parameters at the minimum)
or to view the points of the cloud a bit more marked in solidworks?
Thank you!
Thank you!
