sezione offset pro engeneration
  • Thread starter Thread starter michelealban
michelealban
Hello everyone,
I am a neophyte of pro engeneering and I have a problem with table setting of offset sections. I have already read other discussions but I can't create the section sketch from the xsec menu.
Thank you in advance.
Hello everyone,
What's so complex that we can't? once you select in the menu manager the offset section, asks you for a positioning plan for the sketch (as with a normal sketch) and the positioning (also leaving default), and enter the sketch where you draw your trajectory.
Where do you wrap up?
I couldn't open the sketch window and create the section; I managed to pull it off. thanks anyway for the answer.
but always in the offset sections... is it expected that I create 2 does not make the brakes?
I mean the "arrow displays" I'm looking at it a little so on the fly and I can't make it look like it.
Did someone see similar behaviors?
always works as in the old versions.
Press and hold the dx button on the sectioned view and in the pop-up menu you will appear add arrows where you will wonder where you see your arrows.
Um...so sorry it works.
I must have combined some "adapting" mess to the flight a config.pro...without it works properly.
I'm going to do it again. :
