created pulsar mblocco command
  • Thread starter Thread starter ingmotty
ingmotty
hi to all I am using the 2010 version of autocad at work and I was taking confidence with the various commands looking at me also some videos on youtube.
In particular, I was focusing on the creation of blocks and I realized that the button for the mblocco command is not present on the interface but can only be recalled through the command line. I wondered if it was possible to set the display of the above command.
I do not remember if in 2010 that command was included in the general list of commands.
in every cado command iupers
create a new command by entering as a macro
^^cmblock
then, if you use the ribbon configuration, go to "multifunction bar" and then to "groups".
in the group you choose to drag the new command you created from the window under "command list".
I created it in "personality user interface".
Once, with migration, you will have it on each release below.
if you can be useful.... .
