si, adding a part or changing a already present (multibody).I wanted to know if I can create this reinforcement starting from a set..:smile:
if you want to do it in the environment together you can do it by inserting the part of your ipe and then a new part that represents the handkerchief, or designed separately and then inserted or created directly in the axieme...:smile:si, adding a part or changing a already present (multibody).
Considering that swx supports multibody, it is wasted to draw objects like these in environment together.
with the "saving" function you get a perfect file for that purpose.
... and I wrote... ?if you want to do it in the environment together you can do it by inserting the part of your ipe and then a new part that represents the handkerchief, or designed separately and then inserted or created directly in the axieme...:smile:
in the sense that the multibody is very good but it might be wise to manage as a whole when using a pdm that manages the insertion of codes, processing cycles and raw materials in a management. . .... and I wrote... ?
I don't understand.
Maybe because it's only been 12 years I've been using swx... when the multibody still did not exist....:biggrin:
Yes, adding a part or modifying one already present (multibody).
Right. .in the sense that the multibody is very good but it might be wise to manage as a whole when using a pdm that manages the insertion of codes, processing cycles and raw materials in a management. . .
Here, you are on the good road, unfortunately your file is not multibodyYou mean something like that?
download from quiLet me know.mike the file doesn't open it to me it says rebuild but from empty....
saved with swx 2012 premium sp 3.0and the same mike, in the table instead gives me a mistake and comes out from the program.
Ho capito, tasted.Nothing is there when I open the part gives me a mistake
