We take the epoeia back... :biggrin:hi guys I have to make a stainless steel tee and then cut it laser, I did the piece but I wanted a tip how to make the cut extruded both in the long piece and in the small piece, I hope I made you understand I attach the file...:biggrin:
3d sketch is nothing but the product of the function "intersection curve" and I used it as a reference to trace the sketch of the 2 extruded cuts.great mike, but I still have to understand what you did but I see it slowly, but 3d sketch to what you served? one thing I wanted to tell you the factor k I didn't change it now as soon as I change it a triangle appears in the extrusions, and then if the big piece I have to turn it 180 degrees as I do?
hheee... No. Get used to it!then if I now have to turn the big piece to make sure that the welding comes to me on the opposite side what do I have to rotate? I tried to do it. Look at the triangle that comes out. .
Hi.hheee... No. Get used to it!
When you change your construction geometry so heavily, you have errors.
have lost, or overdefinite, relationships of the sketch.
open the sketch of cuts and system, helping you with "show/elimina relationships", bad relationships.
the problem arises from the intersection curve that is recreated with another entity than the original extrusion.
observation: the sketch you have modified is not fully defined (see guide) which means you don't take into account what you are told.
You are also part of the party fbl:biggrin:ballà l'oecc. . .
really exists already, it is called "Solidworks online guide" and is located under the drop-down menu under the heading "?".Hi.
I take the opportunity to suggest if it was not the case of opening a discussion to be left in relief on the basic notions of solidworks.
es the defined sketches, multibody parts, the ability to save in previous versions, file references, just to say some.
are notions that should be learned before learning soloworks and would be useful for new members coming fasts avoiding so many repetitive questions.
I have not done complete courses and I cannot say if these topics are dealt with or not, I think they have to be the basis, the program is between simple quotes you have to start well and know these things is essential, then for the various functions everyone learns what they need.
the discussion should be tightened and only concerning these basics, if you raise too nobody will read it, like the regulation.
Total sketches defined... And I don't tell you anymore.ok mike maybe I managed it you can only look for the safety that is right, thank you so much I attach it...:finger:
hummm... Now let's make it look like this....ok mike maybe I managed it you can only look for the safety that is right, thank you so much I attach it...:finger:
