hello to all I wanted a clarification from you regarding sketches; must be totally defined, but if I make for example a baking tray with folds, also the sketches of the folds must be totally defined?
It's always better that I sketch them out, otherwise you can risk moving a face inadvertently and change the solid part. .
if it is difficult to define one or more lines, use the fixed function (the button with the anchorin to mean). . .
In that case you are not obliged, the function that creates the padellotto is parametric of its.
However, in particular cases it is possible to do so (lages of different sizes obtained with the same function).
if you want to learn how to draw "totally defined" you can enable
the option in the panel system options (if I don't remember badly).
I keep it disabled because it is really "obsessive", but if you want to learn it is the correct tool.
