Draftsight: in advance opening under forum (+ 2 questions)
reggio
Hello, I don't know how many of you really use to produce draftsight,
As far as I am concerned, (although it does not allow to charge lisp :frown:).
for this I would propose the opening of a sub-under forum not to mix draftsight with swx, what do you say?
2 questions:
1) wanting to replace/publish the value of the quota and replace it with "?" how should I do? within ownership with double clik but then does not accept the "?" instead of the value...
2) Wanting to reduce the size of the white cursor square where should I go? I think I did that month ago but now I can't find the right way.. .
2 questions:
1) Yes, indeed it is a case... But after 30'' I found it
2) here I took a good minute.. options are multiple. .
:biggrin:
:biggrin:
... already ...:redface:
So you're saying that the sub-sunder draftsight board I forget? :wink:
Hello Reggio...
... ehhh, I don't know but maybe you join someone else and you can support it.
Can you believe that with ds I never have and say I ever draw anything?
I installed it for curiosity, but as 2d we have smartsketch 4, I don't feel the need.
It is also true that in 2d we do really little, we say that it is used in cases where a customer sends you a dwg or dxf (which is always in an incomprehensible scale, has open geometries, double lines etc.) where it is the fastest way.
When I start using a new program the first thing I do is to spray all the available options, then I start doing something and at every little hitch or problem I stop and try to learn how to manage that situation.
I have done so with solidworks, and I can assure you that in 1999 it did not have all the tools that can be arranged today... despite the criticism of who I know... :tongue:
All right, listen to us! :finger:
apart from this I find ds quite good in general but not too efficient in others. for example I found myself very badly with quotation styles. in this I find autocad much more intuitive.
I quote the idea of reggio: a subforum for draftsight. I invite others to do the same.
:bekle:
I can assure you that in 1999 he did not have all the tools available today...
13 years ago... (if so much gives me, swx1 what he had, the function "line 3d" :confused: activated only by a living friend in Quebec and the function "circle"? :biggrin:
:confused: Who knows who?
ps: after 4 years we canceled the updates swx, who knows how will I ask for help remaining in 2012? ... and who knows how I will update to sp.4 and sp.5 by ending in late May.. ?
...from re_solidworks open it, to the worst you can always pour everything back into the forum solidworks no? but at least everything remains more ordered and do not disturb users not interested in ds...
Huumm... Perhaps wrong approach, it is proof of your first post with those two questions that were not impossible to solve. . But it is my personal opinion.
For the record, I don't remember how 3d sketches were (I don't even know they were already there) but I can assure you that if you had used the sw at that time you would have risked going crazy: the extrusions and cuts extruded you had to do without preview... You know how to laugh. Moreover if in performing a "separavi" cut the piece erased it directly because the multibody did not exist. . .
I personally appreciate solidworks even though since 2012 I expected more improvement in what already existed (to say one often some views on the design disappear and I have to close and reopen the program) but still a good product.
Hi. :smile:
I tend to be opposed to fragmentation because I find it much worse than the readability of the forum, but it seems to me that the lack of draftsight messages does not justify the opening of a dedicated forum.
http://www.cad3d.it/forum1/forumdisplay.php?f=58Oppure quest altra:
ciao hunter, with deference I allow myself to insist,
I am also opposed to fragmentation, but in this case, just because draftsight with solidworks has nothing to do with it would be a proper separation.
going under solidworks would be perfect because draftsight approaches above all the solidworks user who would find support there.
the scarcity of draftsight messages according to me stems from the fact that draftsight does not find a precise location today, "other cad for mechanics" is too vague and personally, but I think anyone, is brought more to read and write in a specific forum more than in a generic.
I do not say to do something like catia v5 there, catia v5 up, catia v5 down, would really suffice a harmless subgroup :biggrin:
Perhaps you could vote :tongue:
if this subforum should not be done better between generic cads than between those for mechanics.
I imported a 2007 autocad file with draftsight after rescue with the latter no longer opens with autocad, what can I do?
hi, unfortunately I can't answer you with the completeness I want because hunter did not open the under board draftsight (while there are subforum "frequentatissimi" like this: http://www.cad3d.it/forum1/forumdisplay.php?f=86)...
Are you kidding me?
Anyway, probably draftsight is set to save in a "autocad" version above yours, Try to check and let us know.
hi, unfortunately I can't answer you with the completeness I want because hunter did not open the under forum
for your information, I do not open or close forums. I just expressed an opinion, which is as good as yours.
Say hi.
Say hi.
I thought that being you moderator you had more chances than a simple senior user like me... but then, to whom do we have to give her the "colp" of the lack of openness? :wink:
because if you do not select other default draftsight saves in dwg format 2010.
for this a previous version of autocad does not open it.
it does not depend on draftsight, it would have happened also with autocad 2010 and beyond.
try to save it in dwg 2007 or earlier and solve the problem or with edrawings.
to demonstrate the fact that selfdesk is not indispensable.
returning to the main topic of the discussion open a subforum on cad free or freeware does not seem to me to be a subject of little interest.
Hello, unfortunately I can't answer you with the completeness I want because hunter did not open the under board draftsight
c but then, to whom do we have to give her the "colp" of the lack of openness? :wink:
a subforum on the free cad or freeware does not seem to me to be of little interest.
PHP:
Every now and then I read this discussion and I wonder why you have not made the request in the specific area, that is in the forum "proposed of modification to the site" :confused: that is probably the only one that the administrator goes to read.
PHP:
:4425: thanks, fact, welcome and useful support note Here.
