Onda
The script can be as long as you want and you can make him do whatever you want.then so far, nn there are problems for dissected views, transmission organs such as pulley wheels or trees, which as you can well imagine are easily executable, with the polyline command. My question is in short, can I copy and paste a script, put multiple different operations? for example in the sectional view, polylinea, fittings and quotas?
Obviously in the front view, I will use other commands usually circumference, i.e. the juice is I can put more than one function, or I have to copy/paste every script, for every function different from polylinea, which obviously allows me to draw more lines with the same command, because if so nn it was, I should do up it is copy and paste several things, and at that point nn it would be more the same thing.
in case the syntax of, mainly: Can I find you in the links above?
The main difference from working with the mouse is picking.
with the script to put the quota you have to give the coordinate of the point, with the mouse click on the point with the object snap.
apart from this script can be long and do very complex operations, also wanting in 3d, without any problem.
the fittings are not easy to do with the script, because they don't quit picking. You should calculate them mathematically and then make a bow between the two lines. Happy birthday!
try to keep things simple, without instilling you in trigonometry or other complex claims.
learn the creation mechanism from excel and let us see what comes out.
