hole on tree
  • Thread starter Thread starter albotta
albotta
good morning is for a few days that I use solidworks, after using inventor for 6 years. I have this problem.
I can not create a threaded hole on the circumference of a tree using a perpendicular plane to the axis of the tree.
thanks and good work.:smile:
first of all to avoid problems would be good norm to present itself.
in practice solidworks to avoid weighting the file realize the threaded hole without graphically "expliciting" it.
to be able to "see" you have to go to instruments-------options-------property of the document-------details-------- and check the casellin with the option "shaded cosmetic fingering".
Say hi!
did you copy the "superior" plan at a distance of mm= at the shaft radius?
then select the plan and press the command drilling wizard and go to bind the sketch of the point where you want to make the hole.
Unfortunately I only have 2012 available and I cannot give you an example.
Thank you very much eboss, very clear explanation. result also obtained with the 2010 version.
:wink:
but so if it changes the diameter of the tree is screwed.
if instead select the perpendicular plan to the hole and the circular face will be created a tangent plan that will follow the diameter.
I found the guide procedure 2010http://help.solidworks.com/2010/ita...dworks/ref_geom/plane_on_surface_examples.htm
bè for that can put an equation linked to the diameter of the tree, of solutions there is never one depends then on the needs of modeling! :finger:
