isolare vista 2d
  • Thread starter Thread starter lelearo
lelearo
hello, some of you can tell me how you can isolate or "disconnect" view 2d from 3d.
this then can only manage it from the 2d can modify it.
by 2d I mean the .slddrw file
Right-click on the view---- alignment-------- interrupt alignment.
even if I didn't understand the question well!
hi you can save the table as an autonomous design "disconnecting it" from model 3d and you can send it to suppliers or customers who have swx without having to send the model3d.
Alternatively, you can open the standard .slddrw tables directly with edrawings without having to have swx installed. (e.g. if the acq office or the commercial must display a part/axis or table without the need of the technical office.
I mean you want to "work" the carcad design, then you have to save the table in dwg format.
This way you can open the dwg file even with solidworks by inserting it into a new .slddrw document.
Honestly, I never served and wondered why you need this.
It has nothing to do with alignment...
eboss to me also interest in being able to change (delete for example) the lines of the view without touching the 3d.. in catia there was the exploding option since it separates you of the 3d without being able to reconnect it: in practice you have a view composed of lines.. as if it were a 2d autocad file, I wanted to understand if sw also has quesa functionality. . .
exact mike1967.. I knew it from the dxf. apparently then it is not possible. . .
I need it because I have to do some instructions and use a model only by going then to delete the holes present.... without losing the styles of the text (which become standar of the dxf).
Thank you for confirming that you can't do what I wanted!
... but then you can create an ad hoc configuration for those table settings.
easier yet... display states.
