opua
Hello everyone, I’m trying to do an operation with v5 cat that I generally perform with pro-e and ug, the geometry I want to get is pressed that exemplified in the images below.
It is four curves (each with different angles and lengths) that must flow on a guide profile. I thought that this result in catia could be obtained with the sweep command or multi section surface but, I failed to achieve result. .
Can anyone help me?
Thank you very much in advance
Can anyone help me?
