reye
hello to all, I have a little doubt about the orthogonal projection of the attached piece. in the views represented by me, how to highlight the nascorsti edges relative to the empty area placed above? Thank you.
...you could also do a localized section, obviously in the right view.
That's exactly what I meant:Something like this... Forgive me for any mistakes but I did it in 2 minutes.
clearly you will indicate in quotation the fact that the holes are passing.
p.s. sorry but I attached you the wrong section, you have to do the opposite (from the right)
Leave it alone, catholicsexplanation and clear design. Yes, of course the section if it is empty is empty, but the hidden edges must however indicate themit is not clear to me the line placed in the section at the side hole
I think you can leave them, because they indicate that the cuts are passing.yes yes yes nek drawing is not seen but there was an arrow indicating the exact position of the view. So can I take the dotted lines?
No, it is not wrong to put the axes on the semicirculations. :finger:I forgot to erase the axes of the semicirculations that if not erro are wrong.. .
