solokite Guest Jul 11, 2012 #1 Hello,is it possible to measure the perimeter of the section cut (inside the part)? igo image Attachments doc1.pdf doc1.pdf 69.3 KB · Views: 19
nino66 Guest Jul 11, 2012 #2 if you use "cut with surface", i.e. cuts your body effectively with the plane, does it and gives you the sum of the segments.
solokite Guest Jul 11, 2012 #3 nino66 said: if you use "cut with surface", i.e. cuts your body effectively with the plane, does it and gives you the sum of the segments. Click to expand... Devo creation per forza una feature?
